Question in ENGLISH about gearbox ?!
Messagede Pugi_s16 » 26 Nov 2011 15:51
Hi to all!
Sorry, I am writting in english, but I am not from France and dont speak french. ..
I will buy S16 by the end of the year and I know that gearbox is a weak spot of this car. (long shifter, not running smoothly, specialy first and second gear....) The questions is, can this be fixed? Can I change the gearbox from any other car, can this gearbox be tuned up with some better parts ?
How is about the rear bridge? Torsion and suspension? Is this problem about this car? I heard some bad rumours about it, should I be worried or not?
Thanks guys!
Pugi_s16
Re: Question in ENGLISH about gearbox ?!
Messagede onlyy » 26 Nov 2011 16:08
Désolé, je réponds en français.
Pour diminuer la course du levier, tu peux installer un quickshift. lien Beaucoup de sujets en parlent, c'est pas très cher.
Pour rendre la selection plus précise en conduite sportive, tu peux installer des silent blocs plus rigides (l'anti couple et celui de boite en l'occurrence). http://www.mk6.fr/index.php?saisie=0&ca ... d72296983a
Pour le train arrière, bien vérifier la bonne hauteur de caisse avant achat, la présence de bruits parasites etc.
onlyy
Messagede fox02100 » 27 Nov 2011 09:28
only advises you to change the engine support by harder rubber ( parts used on peugeot sport 206 ) to improve precision of gear selection.
He said also that you can put a quickshift to reduce gear stick stroke.
about rear, please check there is no free play between left/right arms and cental tube.
fox02100
Messagede Pugi_s16 » 28 Nov 2011 17:19
Ok, thank you for help! :boire:
Pugi_s16
Messagede ofgod » 28 Nov 2011 20:46
and now you need to introduce yourself in a topic :mrgreen: and later your car :mrgreen: and later your tuning :mrgreen:
ofgod
